Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
what to do for breathers or pcv system
Old Feb 7, 2011 | 09:43 AM
pajamasam's Avatar
Default what to do for breathers or pcv system
I searched around for awhile just now trying to find some ways to put breathers on my carbed lq4. I see you can run a catch can to the passenger valve cover but i dont want to use a catch can. How can I make some breathers for both sides without it looking like complete crap.
Thanks,
Tim
Old Feb 7, 2011 | 10:22 AM
NemeSS's Avatar
I seen a guy using 2 oil fill valve covers with speedinc breathers installed in place of oil fill caps.should work ok.
Old Feb 7, 2011 | 02:51 PM
Nova 404's Avatar
I would think PCV in the drovers valve cover and the Speedinc breather in the filler would work fine.Its what we plan to use on a friends 5.3 powered 62 Nova
Old Feb 7, 2011 | 03:42 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've got two Metco breathers on my car, running two passenger side valvecovers
Old Feb 7, 2011 | 04:51 PM
GC99TA's Avatar
Same here........
Old Feb 7, 2011 | 05:24 PM
daschra79's Avatar
I used the Metco filter on the passenger side and a small k&n breather that I picked up at the local parts store on the driver side. Little hard to see in the picture, but you can see it.
Old Feb 7, 2011 | 05:34 PM
pajamasam's Avatar
Yea that sounds good.
I want to use my exisiting setup so i dont wanna do two oil filler valve covers. I already spent enough on this project. haha
Any other guys inputs... will this work?
Old Feb 7, 2011 | 06:22 PM
sierra69's Avatar
Originally Posted by GC99TA
Same here........
where did you get your alternator bracket?
Old Feb 7, 2011 | 06:23 PM
NemeSS's Avatar
The spending will never cease as long as u own the car
Old Feb 7, 2011 | 06:27 PM
pajamasam's Avatar
Your telling me... i got a turbo camaro that never ends and i was hoping my trans am with this lq4 would just be enough to swap it and be done.....but of course not lol
Old Feb 7, 2011 | 09:37 PM
Z28/2002's Avatar
Here is mine
https://ls1tech.com/forums/13057077-post2.html
Old Feb 8, 2011 | 07:10 AM
johnyrrr's Avatar
Where do I get a set of those bad boys, any mist or oil mess with them?
Old Feb 8, 2011 | 09:46 AM
GC99TA's Avatar
It's a factory LS1 F-body alt bracket that I bolted to the cylinder head instead of the block and added a ribbed pulley in place of the smooth idler. I needed to relocate it due to pitman arm clearance issues. Just shoot me a PM if you want any more pics or info so we don't hijack the OP's thread, but below are a couple links to what I basically did.
https://ls1tech.com/forums/13529959-post52.html
https://ls1tech.com/forums/13530989-post53.html
Old Feb 8, 2011 | 11:37 AM
rojs234's Avatar
That's pretty much the way the factories did it for years before the closed systems on EFI engines. The advantage to using the breather on one side and a PCV on the other is that it pulls fresh air through the whole engine to get rid of the condensation and residue from slight blowby that creates sludge. All cars from mid 60's up did it this way.
Old Feb 8, 2011 | 04:22 PM
Z28/2002's Avatar
I got mine from a non-sponsor so I won't post the link but you can find them with Google, part # MBR0003
I don't have any issues with blowby(misting or mess) but if you do just put a sweatband around them
Old Feb 8, 2011 | 07:30 PM
pajamasam's Avatar
Alright thats the way ill do it then. Thanks!
Old Feb 23, 2011 | 12:12 AM
turbo iroc's Avatar
Hey Tim I found you! Lol hows the Turbo kit holding up? Looks like you moving right along with the t/a too. Shoot me a pm or text message when you get a chance!
