Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Plug gap ??
Old Feb 17, 2011 | 04:21 PM
stewdy1's Avatar
Default Plug gap ??
What should I gap my plugs to
Tr6 plugs
Lq4
Patriot 243 heads
Trex cam
Hp950 carb
200 shot
Old Feb 17, 2011 | 06:52 PM
xpndbl3's Avatar
.035 n/a
you shouldn't be running tr6 on a 200 shot, you need plugs in the 8-9 range IMO and that should be much tighter. .023-.026 for a starting point.
Old Feb 17, 2011 | 07:40 PM
ZONES89RS's Avatar
In-Zane Moderator
Mine are gapped at .045 right now.
Old Feb 17, 2011 | 07:55 PM
Luke_PCScarbs's Avatar
Gap them .035
Old Feb 17, 2011 | 09:27 PM
team39763's Avatar
.035 is good even without nitrous?
Old Feb 17, 2011 | 09:44 PM
Absolutely.
Old Feb 17, 2011 | 10:24 PM
stewdy1's Avatar
I did them around 30 31 should I go back or leave them
Old Feb 18, 2011 | 06:52 AM
ZONES89RS's Avatar
In-Zane Moderator
I would open them up.
Old Feb 18, 2011 | 06:53 AM
speedtigger's Avatar
Old School Heavy
This is interesting. Most of the EFI guys say they are running gaps from .045" to .055".
Old Feb 18, 2011 | 06:58 AM
ZONES89RS's Avatar
In-Zane Moderator
And you see the carbs going .035, so i settled in the middle at .045, LOL.
Old Feb 18, 2011 | 09:29 AM
team39763's Avatar
I've read in a few places that as long as your ignition is strong enough to handle it, you want to run the bigger gap. And like was just mentioned, the efi guys seem to be running big gaps like .055 and around there. I'll try the small gap on my next plug swap.
Old Feb 18, 2011 | 01:17 PM
ZONES89RS's Avatar
In-Zane Moderator
Exactly, thats why i dont want to run a gap smaller than .045.
Old Feb 18, 2011 | 01:21 PM
Old School Heavy
Might be interesting to see what MSD says.
Old Feb 18, 2011 | 02:28 PM
NemeSS's Avatar
I've always ran .040
Old Feb 18, 2011 | 03:19 PM
Old School Heavy
I just spoke to MSD tech and they said that it is related to the compression ratio. He said for 10:1 compression he recommends .040" to .045". As the compression goes up, tighten it up. For example: he said if you hit 11+:1 compression you might go .035". He did indicate that this was not a specific stead fast rule but he did say never go over .060".
Old Feb 18, 2011 | 05:39 PM
ZONES89RS's Avatar
In-Zane Moderator
Sweet, i am spot on then.
Old Feb 19, 2011 | 05:51 AM
six.o's Avatar
I run .030 on my carb setup.I opened the gap up one time on spray lets just say it didnt like it thats all.
Old Feb 19, 2011 | 10:37 AM
3pedals's Avatar
for the guys running wide gaps: if you start having high rpm miss-fire problems, then start tightening the gap.
As cylinder pressure goes up, the resistance across the plug gap goes up, and the ignition has a more difficult time to fire the plug.
Old Feb 19, 2011 | 03:07 PM
six.o's Avatar
Thats what mine was doing so i closed the gap back up
