LS1 Oil Pressure Question?
My buddy just install a LS1 and he's oil pressure is fine when cold.... But when it's hot at a idle is around 18 pounds is this Normal or is something wrong....he says it rises to about 30 when he get on it a little..... Cold at a idle it around 40.... I know on mine it's higher then that but I got a different oil pan and pump.....his is all stock.... Thanks....
That is pretty normal. I believe factory allows as little a 6 psi at idle. Mine does the same thing but even lower. I am geting ready to change the oil pump and I think I am going to shim the pressure regulator spring a little. It is just a piece of mind thing.
