Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Timing curve for Hotcam??
Old 04-16-2011, 02:30 AM
Dans69LS1velle's Avatar
Question Timing curve for Hotcam??
I have an LS1 with ls2 heads, hotcam and a 770 holly carb with the MSD controller. Just seeing if anyone mapped out a good timing curve that works well with that cam. I also have a 4l60 with a 2800 converter, 3.31 gears.
Old 04-16-2011, 11:50 PM
Question
Anybody???
Old 04-17-2011, 04:05 PM
chris-m's Avatar
mine is similar cam and runs fine with about 15deg cranking, 23 degrees idle, 28 degrees at about 2500rpm-3300 rpm and 32deg everywhere above that and at WOT. i have about +10deg on part throttle with the map sensor, so it idles and part throttles at 23-36deg depending upon vac. will give you a start at least. mine is on uk 95 ron fuel so you migth get away with more/less advance.
Old 04-17-2011, 07:47 PM
Ok great. Maybe a little more advance since I have 91 fuel.
Quick Reply: Timing curve for Hotcam??
