Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Idle timing question...
Old Jun 2, 2011 | 07:02 AM
FormulaZR's Avatar
Default Idle timing question...
Ok, here's my question.
I have a carb'd 383 LS1 in my jetboat. I have the idle-1000 rpm timing at 20* right now because if I try 14-16 like I think it should be, then it just flat won't idle.
Any suggestions?
Old Jun 2, 2011 | 07:43 AM
tennerv8's Avatar
I have 28-ish down around that rpm. Mine idles fine.
Old Jun 2, 2011 | 09:56 AM
ZONES89RS's Avatar
In-Zane Moderator
I have 20, but it seems you are possibly cracking the throttle open enough to get fuel because your idle set screws are not giving enough fuel to allow a lower RPM idle.
Old Jun 2, 2011 | 12:08 PM
FormulaZR's Avatar
Right now, it idles at 700 rpm with 19* of timing. Any less and it's not pleased.
Old Jun 2, 2011 | 07:43 PM
FormulaZR's Avatar
Problem solved...just a little carb tuning issue.
