A nitrous option to help with hood clearance.
Guest
Posts: n/a
I know especially with the carb guys, hood clearance is an issue. Also added height can add to cutting on the cowl if you are in a 4th gen.
We have a unique option that we are fond of even when clearance are not an issue. We plumb our spray bars directly into the intake manifold. This not only eliminates the added height of the plate, but allows for two huge advantages.
1) The system is low enough that we can spray directly at each runner. Much more evenly dispersed than fogging the plenum from the top.
2) It is now flowed an built to the intake. Not a generic fit on the top.
It looks a little something like this:
![](http://www.nitrousoutlet.com/images/installs/edelspraybar001%20copy.jpg)
![](http://www.nitrousoutlet.com/images/installs/edelspraybar002%20copy.jpg)
How good are they? We run them on our race car and on Chris's H/C trans am.
Guest
Posts: n/a
![](http://www.nitrousoutlet.com/gallery/albums/75/b7dbdc3fbe03c603b033206f5eb6e131_m.jpg)
![](http://www.nitrousoutlet.com/gallery/albums/75/032053582800bc02602f5f3af8488ab5_m.jpg)
We do indeed.
That is a hard thing to put a certain number on. This is going to distribute very well. Now how good the plate does is going to depend on the intake, the port work, the plate, etc. But that is the real magic in the spray bars. Its going to be correct and flowed when you get it. You jet it and start making passes knowing it is doing it job.
It is definitely a very cool option. As I said this is what we run on all of our single plane cars.
I'm thinking this is a bit of a personal preference question, but doesn't it help the airflow by having the plate / spacer to raise the carb up?
My thought is the preference comes from a) cutting or changing your hood, or b) maybe a little less or restricted airflow. Just curious cause I think Dave and I talked about this when he was setting mine up.
A plate would still have spray bars
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Kind of along the lines of what Tigger said, you either have a nitrous car or a NA car. Even though you can run either way fairly easily the car is always going to be one or the other based on how you build it.
Guest
Posts: n/a
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
how much can you put thru the spray bar? i have a vic jr, will be running a dedicated setup w/ front mount cell, pump and reg. Please pm me pricing on spray bar install and solenoid options. Thanks a bunch.
Guest
Posts: n/a
275$ for just the spray bars.
2-3 weeks. They usually come out faster but this is what we quote and promise to make sure we under promise/ over deliver.
