What Cam for a 6.0????
car craft made 550+hp with a similar setup and a 228/230 112ls comp cam.
here's a link to the article
http://www.carcraft.com/techarticles...s/viewall.html
That's what I built. It's in a 77 Monza. Was 2850lb with old 400 with aluminum heads, not sure with the new 6.0. I should be on the dyno this week. I can't wait to see #'s at the wheels. I'm planning on going to the track next week-end. Car has run 11.06@119 with a 1.42 60'. That was mild 406 with GM Fast Burn heads.Old combo made 387 rwhp.
I'm hoping for 430-440 rwhp. Our dyno reads lower than most and the car has an 8" converter so the #'s will be a little lower. Not really caring on dyno #'s , it's the track #'s that count.
I'll post the #'s as soon as I get them. Should be middle of the week. Busy with customer stuff first. Gotta pay the bills.
Aleck
Aleck
LS1Tech Co-Founder
235/251/113 is pretty big. I was shifting the following at 7000 that went 10.9@123 for on a 1.48 and went 10.7@125 with a better intake and more converter....
11:1 348 cid LS1, flattops
TFS 215's milled
Comp/Vengeance 240/244
1.75 long tubes, dual exhaust, bullets
4800 8" converter
4.10 gear
28x10.5 slick
Stock water pump
LS2 intake
90mm TB
Made about 420rwhp on Dynojet.
TFS 215's milled
4800 8" converter
4.10 gear
28x10.5 slick
Stock water pump
LS2 intake
90mm TB
