carbed ls1 6010 isuues!!!
car runs horible when hot!! i have a msd 6010 box i have a 24x wheel running ngk br7es gapped at 35 plugs are white car misses and breaks up really doggy no power!! could it be crank sensor going bad? cam sensor? i have new msd wires plugged in to boxes brand new and switched carbed still doing the same thing???
Take the pressure up to 7.5, get rid of the cold plugs until you get the motor to run right, and go down on the jets until it won't foul the plugs with the higher fuel pressure. And also, as said above, look for a vacuum leak. After you get the motor to run right, then you'll be ready for the cold plugs.
You said it runs horrible when hot.
Could be fuel pump - regulator - filter. See if you can set up the fuel pressure gauge so you can read it when running.
I assume you set the floats right.
You should answer the questions that keep getting asked about your set up and get that thing on a wideband. You can ask questions on here all day but without real info no one can give you real help.
