Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
altenator help
Old Aug 8, 2011 | 10:52 PM
Gravedigger1's Avatar
Default altenator help
I have a 6.0 with carb and msd 6012 new alt new plug 470 ohm resistor on the l wire i have 6-7 volts out on my ignition but still no output voltage i had napa and autozone check it and it was puting out 14.4 V at both shops any ideas would be great thanks
Old Aug 9, 2011 | 09:23 AM
GNCLONE's Avatar
It is a four pin plug on the alt with three pins?
I know one pin needs 12v key on, another gets that resistor and 12v and the third I just left hanging.
You've got the post on the back connected to the + battery, right?
Old Aug 9, 2011 | 01:00 PM
Default alt
It is a 4 pin connector with 2 wires middle 2 pins i was told and looking on this site that the 12v goes to pin L or second pin on the alt wich has to have the risitir inline also. I am stumped. (yes i have the 12v to bat off the back)
Old Aug 9, 2011 | 02:18 PM
GNCLONE's Avatar
I PMd you. I hope you get it to work. I remember searching for HOURS on this site keyword: alternator. There was some conflicting info and I sort of had to assimilate all of it.
In a car with an ECM the computer handles it. But carburetor people have to do a little extra work. As best I understand it, the alternator needs to see low voltage to kick in, the resistor sort of tricks the alternator into thinking that the voltage is way down. That is the redneck version, I'm sure some electrical engineer has a more accurate way of explaining it.
Old Aug 9, 2011 | 02:54 PM
Gray86hatch's Avatar
I just had mine converted to a true 1 wire. Cost me $50.
No more messing around with resistors.
Tim
Old Aug 14, 2011 | 11:01 PM
Default 1 wire
Thanks had the voltage reg swaped now a true 1 wire (easy) thanks
