Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Traction
Old Oct 14, 2011 | 08:48 PM
Paul57's Avatar
Default Traction
I thought I would try posting this in here since these probably apply more to us old school (carb) types.
Has anyone ever run the Traction Master traction bars... http://www.tractionmaster.com/index.html ?? I considered the Slide-a-links but they don't have them for a '57. The CalTracs sound like too harsh of a ride on the street. I read at least one posting of traditional slapper bars still allowing wheel hop. I want to be able to run my truck at the strip the same way it is set up on the street.
Old Oct 15, 2011 | 08:45 AM
Doug G's Avatar
I made a pair of CalTrac copies and they work fine. I did get a "truck ride" out of them but I think that was me and to much pre-load along with a stiff shock setting.
Had slappers for a long time with my mono-springs....until I bent the springs
The ones you posted may work fine (like Slide-a-link or Caltracs) since it's only there to stop the wrap.
Good luck....it's trial and error
Old Oct 15, 2011 | 09:16 AM
3pedals's Avatar
Avoid the slide a links, go for the cal tracks, you can run some air gap with them just like slapped bars
Old Oct 15, 2011 | 09:26 AM
speedtigger's Avatar
Old School Heavy
I have never been a leaf spring car guy, but I am surprised to see the front is not adjustable with different eyelets to change the geometry. Is that normal?
Old Oct 15, 2011 | 10:21 AM
Paul57's Avatar
I would like it better if they had some adjustment. I was thinking about trying to do a little mod to them so they had some adjustment...any ideas?? I guess if it leaves straight off the line that is all you can ask for, right?? I don't think I would preload them at all since that would surely be (more of) a "ride" killer. I was hoping they wouldn't kill that (the ride) too much since they pivot at both ends and seem to be close to the same plane as the springs. They have a set specifically for my truck which was a little surprising.
