Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
4th gen throttle cable problems
Old Oct 17, 2011 | 07:40 PM
kmspruill242's Avatar
Default 4th gen throttle cable problems
So went to install the throttle cable today. Everything was going reall smooth. HAve a nice Lokar style throttle cable bracket with return spring with a matching throttle cable with nice adjustment abilities. Ran into a problem when I realized the gas pedal travels almost twice as far as the carb linkage does. This is with the gas pedal all the way up until the pedal shaft stops on the firewall bracket then as far as the pedal will go down without any carpet or anything in the way.
I understand I can adjust it so the pedal comes "up" only so far. Problem is, this is a road race car and with the pedal that far towards the floor it's going to be extremely hard to heal toe. I was thinking of welding a bracket half way up the upper pivot point of the gas pedal shaft and mounting a clevis pin. Giving me a batter mechanical advantage so the cable won't move as far in relation to pedal travel. Good idea? Will it work? Anyone else run into this problem?
Or did I completely botch up installing something as simple as a throttle cable?
Old Oct 19, 2011 | 12:39 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
When I converted my '02 I pulled a cable from a third gen F body and it's worked perfect. I think it was a 305 TBI car
Old Oct 19, 2011 | 07:36 PM
S10xGN's Avatar
Adjust the pedal height (throttle closed) where you want it using the cable adjusters, and add a throttle stop bolt between the pedal and floor to prevent over-travel damage to the carb/linkage.
