Drag racing only need 600+ hp.
#41
Thats my fault man. I was so caught up in helping you out that I forgot your motor was an older LQ4 with press fit pins. The LY6 that I have (which GM replaced the LQ4 with) has full floating pins, which is why they'll work for me. Again, I'm real sorry for misleading you on this. But I would give Wiesco a call and see if they possibly do offer a similar piston that accepts the .945 press fit pin. They do make a piston for 3.903 bore with .945 pins, so it's probably worth a call.
Or (and this is a big OR) is it possible to have your LQ4 rods bushed? I don't know if it's cost effective, but I would certainly think it would be possible.
I also edited the pin size information in post 35 so it doesn't lead anyone else astray. .943 floating pins; .945 press fit.
#43
I guess at this point I can't say that I blame ya given your apparent lack of piston choices with the press fit pin rods. I'm glad GM came around on the bushed rods but hope that Wiesco or someone else will come around with some 4 inch pistons for the press fit crowd. There are so many of these LQ4's being built on a budget these days that it would only make good sense for them to support it with a stock rod capable piston.
#44
lol thats funny as hell anthony I asked if you went to piedmont and the picture you have my neighbor is standing in it!!! The black guy with dreads is Mark he has the Helter Skelter 68' Camaro. I was thinking of a chevelle for some reason when you said nova.
Here's what I would do.
Take your block have it done .030 over forged rods and pistons super vic intake, 950 cfm carb, ls3 heads, ls3 valves, 247/263 112lsa cam ground on LSL lobes, and do some slight porting to your heads and maybe some bowl work if you can. That should net you a solid 500rwhp and an easy 600 crank horsepower on motor alone. Throw the gas on it and it should make the index your wanting to run at Piedmont.
#46
#47
and op they do make forged press pin fit pistons for LQ4 motors with stock stroke and rods.
http://www.texas-speed.com/p-771-wis...22-stroke.aspx
for forged 6.125 rods
http://www.texas-speed.com/p-728-wis...22-stroke.aspx
and those are just some of the domed ones. there are flat tops too. and dished if you want to go the FI route
#49
Old School Heavy
#50
incorrect info. they do make a vic jr for the L92/ LS3 heads. they dont make a super vic for the L92/ LS3 heads. but for cathedral heads they make a super vic, vic jr, and a performer. holley also makes a tunnel ram style manifold for the L92/ LS3 heads but nothing for cathedral heads.
#53
yes one is just for a stock rod and not as much compression and the other is for a aftermarket forged rod and more compression.
if you went 4.030 bore and stock stroke with the +12 domed piston, stock 70cc L92/ LS3 head and a stock GM MLS .051 gasket your compression ratio would be around 12.0:1
if you went 4.030 bore and stock stroke with the +4 domed piston, stock 70cc L92/ LS3 head and stock rods, with GM .051 gaskets your compression ratio would be around 10.89:1
now if you went 4.005 bore with either of those pistons and all other variables being the same as above your compression ratio would be slightly lower due to less cylinder pressure from the smaller bore size.
#56
Here's my combo so far.
lq4 .030 over
cnc ls3 heads
wiseco 12cc domes. for 13.1 comp.
stock crank
scat rods.
have to get a custum cam ground, and havent decided on an intake yet. holley came out with new high rise i'm looking at. havent seen any test on it yet with a single carb. should be well over my 600hp mark
lq4 .030 over
cnc ls3 heads
stock crank
scat rods.
#57
lq4 .030 over
cnc ls3 heads
stock crank
scat rods.
lq4 .030 over
cnc ls3 heads
stock crank
scat rods.
my LY6.
Any updates on your build?
Mike
#59
Ooops, sorry......you're right. I posted the wrong link. I meant to post their Pro Tru catalog which lists a 4cc dome piston for 4.00 and 4.005 bore (and many more). But they also may not be what you're looking for since they utilze the stock rod. Personally, I think these pistons are the cat's *** because I already have good Katech rod bolts and actually trust the stock rods and crank for my power level. Plus I called and priced them. They were like $550 and come with rings and wrist pins. Here's the link I meant to post. 11.0:1 with a 65cc head. I'm not sure what gasket they're calculating that with though. http://www.wiseco.com/Catalogs/ProTr...rChevrolet.pdf
