Extremely rich on a cruise. Tuning help please.
I have a holley 1000 and a qf850. Both of them mounted to my 406sbc are very rich on a cruise even though my idle af are perfect 14.0s and wot af is 12.9.
Ever since I have went to a glide with a 5000 converter it has been this way.
I feel the problem is probably in the size of the emulsion tubes in the metering block seeing how airbleed changes seem to have no effect.
Anyone have any useful info on how to lean this thing up?
Old School Heavy
Make sure your powervalve is good like Paul suggested. Once you are sure that it is, you can drill your PVCR(Power Valve Control Restrictor ~ I think that what that stands for lol).
On my carburetor, I jetted up significantly for a good WOT AFR. This caused my cruise AFR to be very rich (approx 12.5). So, I drilled my primary PVCR from .040" to about .051", then jetted the primaries down 4 sizes. This gave me a cruise of just over 14:1 while maintaining my WOT AFR ratio of 12.8:1.
