LQ4 plan....
300----motor (already claimed)
300-400----Cam/springs
600----machine work (already talked to shop...labor only...worse case)
700----pistons (.030 over....forged,,,flt top...Mahle w/ rings)
600----headers (1 3/4 or 1 7/8)
350----MSD box
1000----misc. (bolts,gaskets,motormounts,oilpump,oilpan ???)
300----intake (VicJr. ?)
All prices approx.
10.91:1 with a 0.00 deck and a .040 gasket, milled 317 heads for 65cc (for now) 23X/24X @.050 cam on a 110 LSA.
Now...pic it apart and est.HP/TQ
It will be a carb motor ..what you guys think ?????
What rods are in your engine? I'd maybe look at a good aftermarket set to go with the pistons depending ont he RPM you are
If you are going to go L92 do it now and ensure the cam is spec'd for it. With l92 heads and 230's/240's I expect your motor will turn some RPM!
I'd under-drive all accessories depending on how much RPM your turning to get a few extra HP and decrease problems. One of the guys I know had a 355 SBC in an 81 camaro that ran 9's but he was turning well over 8600 at the top as shift we at about 8600 of the 1/4 Was even starting to loose oil pressure. He always had issues with his alternator belt slipping at high RPM.
Bruce
550+ FWHP I hope
I'd like to do the L92/LS3 heads now... but may have to wait ?
Yes BP & B.....standard procedure IMO
This will be on budget and for under $4500 in the car running. I hope
No idea on the stock LQ4 head flow rate.
Most guys say that the L92 heads have a weak exhaust port ratio, so they are using a split duration of about 8 to 12 degrees.
