ported iron 6.0 heads a good choice???
im starting a new project and picked up a iron headed 6.0, what do you guys think about porting does iron heads? i heard that they are the same as aluminum 317 but iron. Any ideas would be appreciated!! thanks
Originally Posted by Paul57
I don't know if a porter would want to use their cutters on iron?? At least, I don't think I would want to dull them up more/faster for one set of heads.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Thats a good one
You can port out Iron heads just fine. Cast iron is actually pretty soft. Nowhere near as soft as aluminum of course, but a tungsten carbide bit should not have a problem.
I have both the Iron heads and the 317 aluminum heads. The cast iron heads LITERALLY weigh 30lbs a piece MORE than the 317 heads. That is each one! so 60lbs total just by switching heads. These were weighed on a shipping scale, not a bathroom scale.
The .4" longer crank may cause you to run into problems depending on what tranny combo you want to run. For example, you cannot run the T56 with that crank. The bell housing won't reach the block before the input shaft bottoms out. From what I understand, you can run any auto though. You also have to be aware of this for what flex plate you run too. I currently am battling this dilemma myself.
The newer cranks have a spacer you can actually pull off, but the truck engines that came with the iron heads don't have a spacer. The crank is actually longer. The length difference is where the flex plate/flywheel bolts to the crank. This is why you have to be conscious of the difference when buying your flexplate.
If the iron heads are the same as the 317 aluminum heads.... The 317's flow the same as the 243's, but the 243's will raise your compression ratio.
Early 6.0's were only offered in front of the 4L80E which uses the old SBC style case/converter. This put a .4" gap between the crank flange and converter nub. Those older cranks had the flange cast into the end to account for the difference where later cranks used a separate adapter. This way GM can use the same crank for 5.3/5.7/6.0 and not have an individual 6.0 crank
I like that long flange 6.0 crank
Engine I built with it still runs 9s on spray with it in a swapped 3rd gen.
I kept the old iron 6.0 heads, but later sold em to a guy who used them on a 5.3. And ran em for a long time with a mpt70. Never came apart or any issues, and he used stock new TTY bolts and the old grafoil 5.7 ls1 heads. Iirc saw up to 15psig all the time.
I did take a carbide burr to em and cut out the flash, smoothed the chamber to smooth shiny finish and exhaust port also.
Ran fine, maybe the extra weight kept the heads from lifting with those junk gaskets and bolts
Bingo..... Please don't take them to a scrap yard, you can sell them to the right people if you look in the right places. Scrap yards pay by the ton, you're not gonna get jack s**t for 70lbs worth of heads.
