Project EFI to Carb in my 2007 Silverado
I feel like I'm over thinking this whole thing...And it's pissing me off and making my head hurt. I don't need my pcm for anything. I have a Racepak that tells me mph, volts, ect, oil pressure etc...It doesn't control the tranny because its a MVB. I'm putting a carb on this thing, so it's not controlling any fueling. I have an MSD 6010 ignition so it's not it's not being used for any timing or anything like that. Basically, the bcm is being left to control lights, radio and A/C controls.
My thinking is, and I know a guy who did the same with a 99-02 truck, is that i could remove the entire pcm and harness and not have any worries since it doesn't control the lights, the radio, the power windows/locks, the heat/ac etc...Worst case scenario I have to figure out which wire off the key is crank and wire it directly to the starter???
Thats not worse case. Thats exactlly what you need to do. The truck will just be able to start in gear.No biggie,just make sure your in park lol. Need 2 get under the colum to the ignition switch and find your witch one makes a closed loop when you hold the key on. Its really pretty simple= or just put a push button on it make it really simple.
Pepole on here tend not to answer when they dont know(cuz its out of the normal and they think your going backwords and a dumb idea). Im all for it bro its your truck . I have switched alot TBI and the Pre Ls vorteches to carb. It really makes a diff on the tbi as they were **** lol. Its the same as someone swap a ls into a older car just the oppisite way lol
Got most of my wiring concerns figured out. Atleast in my head lol
A couple more pieces showed up yesterday. Holley HP-150 pump, Holley 12-803 regulator, and XRP fittings.
Only thing I lack now is the fuel cell and fuel filters and I'll get started on this thing
It will be interesting to see how you like this when its complete , its a different path than most but that is whats cool about it , the more ways documented the more choices people can make in an educated manner in the future....
this.
w/ the MVB 80 would it be safe to assume that you have an aftermarket shifter? if so it probably has the provisions in it to put micro switches to make it only start in P or N. otherwise just put a microswitch on the shift linkage under the truck so when its in P it engages the switch, then come off of the start switch to it then to the relay then to the starter. You should be able to use the factory switch. very worst case the ignition switch won't work that way and you have to put the key in turn it to run and put a start button in the truck.
the bcm should only need to receive signal from the ignition switch to indicate off, run or start. things like speed sensitive locks, maybe reverse lights and a few other minor things may act up or not work at all but w/ the trans swap you may already have these issues.
Thats some good looking stuff there!
Worked last weekend on putting the new carb on, new fuel system and ignition.
All the old engine harness.
Carb and fuel cell in.
Fuel pump and filter
My girlfriend putting the first 5 gallons of corn juice in it
Shitty video of the first start up
http://www.youtube.com/watch?v=N-yjbmeNCEU
http://www.youtube.com/watch?v=NadmZ1LnJ2o
Most everything went very smooth. Everything works after the install and cutting all those wires EXCEPT my power windows and locks. Got to figure that out then I'll be hitting the track
i had the same issue, make sure the two connectors under the fuse panel are plugged in. idk how to describe them, but when you open it up youll see what im talking about if they arent plugged in
#32
Well, got to take it to the track this weekend. This entire conversion is a success in mine and the people who are helping me's, mind.
With the carb EXACTLY HOW IT CAME OUT OF THE BOX FROM QUICKFUEL, the truck picked up 7mph, yes 7, naturally aspirated over my previous best with the factory fuel injection. The 60' was more .1 better than my previous best on motor and it was almost .6 quicker in the 1/4 over my previous best. Red Truck then made a couple quick changes to the carb and we picked up another .02 and 1mph.
So, with one day at the track and minimal tuning, we picked up more than .1 in the 60', almost .6 in the 1/4 and 8mph, on a not so good sunday test and tune track.
To say the least, I'm very happy with the truck. And we're only getting started.
#36
#37
The weather was kind of crappy here this weekend so I didn't get to go to the track to do any more testing. It did clear up enough for me to put my new nitrous plate on and play with my new LM-2 wideband and do some idle tuning
NOS CROSSHAIR
NOS CROSSHAIR
#39
HAY im don same swap but i need to know what wiring to cutout to clean it all up where did you find the information on that or did you just figure it out either way it would be great if you could give me some pointers
#40
You reply to an 8-year old thread and expect an answer??
