Fuel system
370ci forged LQ4
Ported/milled LS3 heads
237/249 .6xx/.6xx 110+4 lsa
Ported victor jr
950 holley
NX plate wet plate kit
I am going to be running a inline fuel pump with my factory carb'd fuel tank. My question is, How do I run the line for the wet kit? Can I run a line from the stock fuel pickup to the pump then run the line to the front of the car. At the front of the car I can put a Y in the line running one side to the fuel solenoid and the other to the fpr for the carb?
N20 solenoid--plate kit
fuel tank--pump---filter-----<
FPR---carb
Tell me if that sounds right. I plan on dead heading the fuel pump and not running a return.
Let me know if you see and changed that need made.
Thanks,
Dustin
http://www.centuryperformance.com/fu...e-spg-140.html
Now, if you upped the line size and use a expensive high end pump, and can figure out how to make the feed line in the tank larger, yes, a T will work to use the nitrous and engine fuel, i opted for the first, and it was great, just used a holley blue with a dead head regulator for the nitrous.
You are on the right track, 3/8 will supply both, but the braided AN lines are the way to go, i am not sure what size you need in specific detail, but there are several here that can chime in and give a detailed instruction to make a safe and excellent setup.
