Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
help!
Old Feb 11, 2012 | 06:21 AM
camarozz383's Avatar
Default help!
Ok guys im doing a swap and need some help, I got a 5.3 that i will be changing over to carb, im using a comp cam (54-600-11) edelbrock and msd ignition controler 670cfm helley carb , Im also using my older t5 to bolt up to this set up, i know the t5 cant really handel the power or torque, but thats all i have for now, can someone tell me what i need to bolt the t5 to my ls 5.3? the t5 bolts up fine but im wondering what flywheel and clutch i need, or any other parts? any help would be great, thanks
Old Feb 11, 2012 | 08:42 PM
S10xGN's Avatar
Can't help you on the clutch parts, but if you want to beef up that T-5, you can check out Astro and G-Force. Also, the weight of the car and final drive plays into it...
Old Feb 11, 2012 | 08:56 PM
ZONES89RS's Avatar
In-Zane Moderator
The input shaft is not long enough to mate with the pilot bearing.
