:-) just home from the engine dyno.....
#82
Just curious since it was such a long time ago if anyone's used the pistons out now already with the notch and obtained close to 10.5/1 compression without milling the heads down or changing the head gasket.
#83
Using LQ9 pistons (flat tops) would get you 10.0:1ish....Stock gasket is .051, you could go to a .030 gasket to up it to around 10.5:1 and a .020 would be around 10.8:1
Unless you change to domes....I don't see it
Shave the heads either .020 or .030 and get the gasket needed
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
