LSx ~ old school gauges??
^^ OK so if you're running aftermarket gauges, there's your solution.
If you're running factory gauges, here's the solution (supposedly):
Standard motor products TX111 (12551708) is a 3-wire coolant sender. Here's a photo:
![](http://i281.photobucket.com/albums/kk223/MnJShuey/Links%20for%20websites/3wire.jpg)
It threads into the head in the same spot. A 3-wire pigtail is also needed, and you can get them both from guy on Ebay who has a ton of LSx swap stuff for sale. Just look up his name:
joemama2
He's a few bucks higher than Rock Auto on the sender, but the pigtail is only $11.00, and I've seen them listed for $30+ elsewhere. I say buy it from the guy who has an LSx powered 81 Trans Am. Problem solved for $43.00 shipped/both parts and no drilling required.
joemama2
Ok, my car has an Autometer mechanical oil pressure gauge, as stated above, can I buy the metric to npt adapter and screw it in the location at the top rear of the block? Anyone have any pics? I tend to double up on dumbass a lot.
I used this adapter from speedway:
Item Details:
16mm-1.5 Male to 1/8" Female
http://www.speedwaymotors.com/LS-Ser...ter,20928.html
I know there are other business that offer these, that have been placed on this site.
Item Details:
Old School Heavy
I removed the factory oil sender, broke of the plastic cover, removed the guts and tapped it for pipe thread. This allowed me to use it as an a adapter for my Auto Meter gauges:
![](http://px6.streetfire.net/0002/01/38/2051083_600.jpg)
Here are two shots of the finished product:
![](http://px6.streetfire.net/0002/01/48/2051084_600.jpg)
![](http://px6.streetfire.net/0002/01/58/2051085_600.jpg)
I drilled and tapped the water pump for my Auto Meter temperature gauge sender:
![](http://px6.streetfire.net/0002/01/68/2051086_600.jpg)
They say great minds think alike. I gutted my stock oil sender and discovered the hole in it seemed just smaller than the little clear plastic tube on my old-school mechanical oil gauge. It was a tight fit (which is good) and then I put a blob of JB Weld on there for good measure.
