LS Combo
https://ls1tech.com/forums/drag-raci...-n-any-cu.html
Edit:
more for your reading pleasure....
https://ls1tech.com/forums/drag-r...ck-ci-h-c.html
https://ls1tech.com/forums/drag-r...s-engines.html
https://ls1tech.com/forums/drag-r...1-74-bump.html
https://ls1tech.com/forums/drag-r...s-any-c-i.html
https://ls1tech.com/forums/manual...peed-list.html
https://ls1tech.com/forums/nitrou...fast-list.html
https://ls1tech.com/forums/nitrou...rous-cars.html
Id say keep it right at 12-1
mid 250int -260 ex lobe 670 lift comp huc lobe
TFS 245 cathedral port head w opt nos exhaust port
supervici ntake w 1000hp carb
good 3 speed with correct converter and 4.10 gear
That should run nines(9.80-9.65) on motor pretty easily and would prob need to be sprayed about 225-250hp to run about a sec quicker
