Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Msd 6ls question
Old May 9, 2012 | 07:01 PM
boosteds10's Avatar
Default Msd 6ls question
Will the msd 6ls box pull timing when referenced to boost from the map sensor?
Old May 9, 2012 | 07:44 PM
Pop N Wood's Avatar
The manual says it is capable of providing advance or retard for either vacuum or boost. It can be set to use up to a 3 bar MAP sensor and allows you to modify the curve at boost pressures.
So while I have never done it from reading the manual I would say yes.
Old May 9, 2012 | 07:57 PM
boosteds10's Avatar
Thank you! That's what I needed to know.
Old May 9, 2012 | 10:54 PM
ZONES89RS's Avatar
In-Zane Moderator
Thought i told you before. BTW, turbo i got from you is on a guys TA making 560 RWHP and 640 TQ at 10 pounds, that is on a stock 6.0 with a blower cam.
Old May 9, 2012 | 11:11 PM
boosteds10's Avatar
You sure you got the right person?
Old May 10, 2012 | 08:01 AM
ZONES89RS's Avatar
In-Zane Moderator
Well, think I confused you with Daniel, a local friend that did a ls1 swap in his s10, his DN here is Boosted s10, sorry.
