THIS close to driving...small prob with TV cable bracket?
I have 3 things left to do on this truck: alignment, exhaust, and adjust the TV cable. I'm taking the truck on Tuesday morning to get the alignment and exhaust done.
I have an Edelbrock carb #1806 and bought the Edelbrock specific manifold bracket and geometry brackets for the TV cable. The TV cable is a universal from TCI.
The manifold bracket isn't far enough out to line up with the carb brackets. It's at an angle. Maybe I should bend the bracket?
![](http://pic100.picturetrail.com/VOL1152/4407107/9319904/402636910.jpg)
Using this bracket: http://www.jegs.com/i/JEGS-Performan...ductId=1250058
Anyone gone through this before and how did you fix it? It might not be a problem? Even if it says it's for an Edelbrock, is it the wrong bracket?
Jeff
Jeff
Russ,
Here is the bracket. Sorry for the broken link.
http://www.jegs.com/i/JEGS-Performan...rentProductId=
I can take a side pic and post it a little later. Thanks.
Jeff
Jeff
