wiring my f body alternator carb ls1
can you chaps help me i need to wire my f body alt (the car is not an fbody) but i dont know which wires i need to hook up to im hearing 5v here and resistors there and its getting a bit confusing.
thanks in advance
thanks in advance
This link has pretty simple instructions.
https://ls1tech.com/forums/conversio...aq-thread.html
Beside the main power out you just need to hook up a single voltage sensing wire preferably through the dash charge light. If you don't have a light available, then use a resistor like shown in the diagram.
Had a similar ?
I don't have an alternator at all. Was thinking of ordering one of the one wire deals off Ebay. This is a carb fox body. Car doesn't have a light, but does have an autometer volt gauge. Do I still need to use a resistor?
In-Zane Moderator
Nothing, it just lines up, one side needs the dowel removed,, then a washer or two between the bracket and alternator so there is no stress when the bolt is tightened. Used a newer alternator on the 85 TA, had to grind the bracket a bit, but the 88-92 v8 and 88-95 v8 half ton alternator are best.
Thanks for the help guys. I got my F body Alternator on my car. Got it out of the bone yard and they left the pigtail on it for me. I ran the wire on the pig tail to a light I bought at the parts store and put in the dash, then over to 12v with switch on and it works great.
Just like link above.
![](http://i172.photobucket.com/albums/w25/streetknight2/wiring.gif)
Hello guys,
I have been trying to figure out this problem i am having on my carbed LQ4.
I have changed the alternator after it stopped charging(probably wrong wiring).
the second alternator is charging fine but it is not compensating for voltage drop.for example, once the engine is running the battery reads close to 14V , but as i turn on various electrical devices(fuel pump, AC, Head lights) voltage decreases close to 9V. and i am sure it affects the perfomance of the MSD box.
I have read many threads and posts on how to wire the alternator, but they are all a bit vague when it comes to model number.
i am using the holley brackets for the CS130D alternator and R4 compressor.
using a pigtail that i cut off an LS harness, using only the two middle wires.
i tried connected a resistor in the circuit just like it shows in some of the schematics linked to this post , but nothing changed.
any suggestions ?
any suggestions ?
