What engine assembly manual
I'v got my engine @ the machine shop getting the crank turned & don't have an assembly manual , I'v never done an LS before, any thought on a decent one?
In-Zane Moderator
Man, i thought engines are all the same, once you have done one you have done all, with exception to different torque specs.
The LS just needs specific cover installation and the rear cap faces the other way or it will lock the engine and not even turn over, otherwise, it is a small block with a few more bolts in the mains.
There are many specific steps in rebuilding an LS engine that differ from the traditional SBC engines. I used a book by Chris Werner: How to Rebuild GM LS-Series Engines, item SA147. There are probably others but I would definitely get one for your rebuild.
I found this a few years ago, its in pdf file format. Its the LQ4-LQ9 GM service Manual
http://www.pleasurecraft.com/manuals/L510016.pdf
