I'm Running a Q-jet on my 5.3 and Love it
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
I've seen people asking about running a Q-jet, I've gotten mixed answers but I've never seen anyone actually do it..
I did... I'm running a 1968 Q-jet from a stock Vette 350 and it absolutely runs like a champ.. WAYY better than the Holley 750.. No matter what I did to that carb it ran ok...but PIG rich...
The only downfall is I had to run a shitty adapter.. but i don't even notice it..
I used an Olds 307 throttle bracket (for the correct geometry for the Th2004r TV cable) and fuel pressure is set at 6PSI
Ultimately this setup is as close as im going to get vs EFI but its a hoot.. Im currently doing my research and I plan on going back to EFI but I still have some learning to do.. so in the mean time Ill play with carbs..
Heres a pic and some video
![](https://sphotos.xx.fbcdn.net/hphotos-ash4/486584_10150899249752190_876678005_n.jpg)
http://www.youtube.com/watch?v=4T7iQgxHRs8
Thanks
Basically you can't expect a Q-Jet off a big engine with a lower power band to perform the same on a smaller engine with a higher power band..
In my case I got lucky.. A took basically a stock Q-jet off a 350 Vette motor and tossed it on a motor thats only 25 cubes smaller but has a better combustion chamber and different power band.. It seems to work perfect.. I need to get a wide band 02 to really dial it in but as it sits right now it runs badass.. 2nd gear pull from 40 on up is amazing the carb doesnt miss a beat.
I'm having horrible luck with my 750 mechanical secondary on my stock 5.3 in my s10. I have a q-jet laying around and after reading this I think I will buy the adapter and throw it on and see what happens.
In-Zane Moderator
I don't want to be a a hole, but it is a duh factor, a 750 mechanical, wide open on a 5.3 in a car with not large converter that has some weight is not going to perform as you wish. A 650 DP maybe, but not a 750. A 750 vacuum secondary would be fantastic. If you have a spare a jet, try it, or sell the 750/trade for a VS.
Yea had I known that in the beginning that's what I would have bought. My plans are a big cam and 243s eventually so I bought the carb with the intentions of doing all that. But for right now with stock internals, its definitely not a good choice.
Edit: actually zone, at wide open throttle it runs hard. It's the part throttle cruising and acceleration that really sucks. It misses and bogs at about 1/4 throttle. So you either have to barely give it any throttle or give it over half. It's a pain for daily driving.
A Q found on a 305 might suit a 4.8 better as well as a carb found off a 400 or 403 Olds might be close in the ball park for a 6.0.. Just a thought.. My opinion is not law just from what I've experienced..
Also mentioned before if your running a wild cam a Q-jet probably wouldnt be a good carb for that application because they so depend on the all important vacuum signal from the motor..
#32
Well I threw the q jet I had on my truck tonight. I think it needs rebuilt. It's squeeling super loud and running like crap. I'm thinking its a loud vacuum leak but have yet to trace it. Ran out of time tonight. I did drive around the block and it ran better except for the inconsistent idle and loud noise.
#33
#34
Yea I have no idea where it came from either. I took it off and replaced it with an identical one and now it runs perfect! I couldn't an happier. Now my biggest problem is traction. Haha
#35
Hell ya.. It would be nice if someone made an intake with a spreadbore mounting boss.. but that almost seems unreasonable..
#36
LS1Tech Administrator
Received 1,692 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I think the small primaries of the spreadbore Q-jet makes it easier for people to toss one on and get decent part throttle performance, and also good driveability on a street engine with little effort. Holleys need to be sized properly (even in VS format, IMO) to give crisp part throttle manners, and they rarely just drop on and perform their best. You really need to work with a Holley out of the box to get best results; usually they will run if you just toss them on, but you'll never get ideal performance without some adjustments. There is a lot of mis-information on Holley tuning that leads people down a path of frustration and poor results, and then this leads to people posting about how "holleys are junk, POS, etc.". If Holleys really were all hopeless junk, then how can you explain all the cars that run well with them? It's all in the tuning.....same as with any fuel delivery setup.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#37
In-Zane Moderator
Yea, I have been lucky and dropped them on and also had to spend a day getting them in the ball park. But I do run a VS on my 4.8 with zero issue. I am going to try a edelbrock on my 4.8 going in my 91 RS to see if I can get over 25 MPG out of it and **** off the efi guys that simply refuse to believe a carb can get decent economy.
#38
The wide band O2 sensor helps big time.
#39
recomendations on a wideband? Only thing i don't like about my setup is it stinks when i start it in the garage etc. Ive tried getting the smell cleaned up by adjusting using a vacum gauge, but I probly need to check jetting too.
#40
Main jets won't have any effect on how it smells (or runs) at idle. If you don't have cats, it's always going to smell some. If you have a cam with a lot of overlap, it's going to smell even more. This is still the case even with a perfectly tuned EFI setup. Verifying your jetting with a wideband is a good thing, but this isn't going to clean up the idle any further.
