What should Target AFR be?
With an NA setup i would add that colder plugs and pulling timing a few degrees may need to be done as well to prevent detonation or overheating of the spark plugs if running 91/93. Lean AFR's are more efficient but also a hotter burn because there are less excess fuel molecules to benefit whicking heat from the combustion chamber as a whole.
If you run 14:1 or higher AFR in a high CR setup a few extra steps must be taken into account.
