Help me dial in!!!
Issues I am trying to find solutions to
1) TIMING!!?!
I have an Edelbrock Control Module. Built by MSD, but not able to program.
I have a Comp Cam...
Specs- Lobe Separation 113
Valve lift 617 intake 624 exhaust
Duration @ .050 231 Intake 239 Exhaust
2) Where should power band be? and what would be safe to rev to?
My setup...
LS6
Carb Edlelbrock performer RPM Ls1 manifold
Holley HP 750 carb
AFR 210cc Heads
Doug Thorley headers
and the Cam specs above...
Some peeps might just say to take it to a tuner/ dyno tune it... FUNDS ARE SUPER TIGHT. gotta make due with what I got.
I know its vague and some of you may not even know how to answer... BUT if you have any idea, holla back. Fill me in por favor.
Your ultimate solution may be the MSD box but you should be able to make it run with one you have. Try pill #5 and run a map sensor. That may be a bit much timing on the top end so just listen for detonation and see what happens.
With an LS6 bottom end and I assume good, matching valve springs for that cam you have you want to rev that bitch a bit. I wouldn't hesitate to go to 6700 RPM. Once Zones gets on board I am sure he will tell you higher. That cam with AFR head will have a pretty strong top end, so don't be surprised if it is still pulling hard at red line. With no rev limiter in that eddy box you will need a shift light to keep from over reving it. The red line is going to come up way fast. It would have come up faster with a single plane intake, but the performer should work well with your relatively heavy car.
You should have a fast ride with what you have now.
This is her!! My all black dream... Yea I have never taken it past 6300.. And it felt like it was pulling harder at that rpm than at any other speed.
We had the springs in those AFRs matched to the cam.. Did a few other internals too.. it feels fast! just have not really done any dyno runs or Quarter miles yet. But I built that bitch to drive! Imma find out what she can do. Once I get it dialed in of course
