6.0 to the 86 TA
#65
lmao, yeah i'll think about it. just waiting on a few more parts and a more money mostly money. what started out as a semi budget build followed the trend of past projects and became a not so budget build. i got the pistons flycut last weekend and my transmission guy called last night and i pulled the trigger on what he wants to do. i'll have to line up with you to show you how it's supposed to be done!
if you want to buy the truck it could be picked up for exactly what i have into it. i wish i had a boat right about now...and padded pockets.
#66
Yea, let's line up my 3300+ pound stock 6.0 with cam against your sub 3000 pound truck that has real heads and the works, lol. There is a reason I rarely lost in my RS, I chose my battles big enough to matter and small enough to win. Perhaps when I do a fox body, then we can play! Lol
#69
nope. i want a full street truck. full weight with A/C and power steering. i even plan to race on street tires.i got tired of spending 30 minutes swapping tires, pulling tailgates, shortbelts, etc etc. i want to roll in and run it exactly how i run it on the street. i definately want to go with you when you hit the track.
#71
Not BS actually, when I sold a t56 and had to ship it, it came in at 125ish with bellhousing. Thats not including clutch,flywheel etc. And also dry. Weighed my th400 short tail shaft other day was 130lbs dry. Not including converter though. Maybe you're just tired from throwing your t56 around the shop all day, you had you use a jack to get the 400 in lol.
#73
Point is the whole setup for both is within 10 lbs of each other. Have fun anyways. Car sounds good.
