Experienced advice requested ref carb selection
I am almost done with a sbc to 5.3 swap down here in South Florida.
I am keeping my old Holley for the sbc. I need to purchase a new carb for the 5.3 setup on my Chevelle. The car is running a th400 3500 stall to some tall gears. 224 cam .581 lift 112 Lsa, PAC 1218 springs, Edelbrock dual plane, 6ls. Stock bottom. Mid headers.fresh valve job on my truck heads, milled flat minimally, stock height head gaskets. Car will be mostly street weekend driver, track under 6 times a year. Any educated suggestions on brand, size and configuration would be very much appreciated. Cost is not the main issue. I want reliability and power.
I have looked at the quick fuel slayer 750, the Summit 4150 kits, and a number of Holleys. I don't know any better. Please advise any suggested directions to go here. Mec, vac, 650,750, adjustability etc. Any of my Ls experienced buds are all running fi. These heads clearly flow Better than any sbc I have played with so my guesses are likely to be no good.
I think most guys on here would recommend something in the 650 cfm range for a 5.3, especially with your set up.
If you do go Holley their street avengers and HP carbs supposedly work on LS motors pretty much right out of the box. Classic double pumpers might need a little more tuning but work just fine once you get them where they need to be.
What ever you do consider investing in a wideband O2 or at least borrowing one. Pretty hard to get the tune right otherwise.
You will need to calibrate the power valve restictor orifice and possiby the idle bleed and feed retrictor for a good clean cruise air fuel ratio so just plan on buying a good wideband set up.
This issue has taken me beyond the advice of just the carb and opened my eyes up to the rear gearing and terribly insufficient 10 bolt in my car. Thanks for the responses. I am getting a wideband and a mech sec Quick Fuel. Oh yeah, and a new 12 bolt. Now I'm looking at brakes. It never end$.
I almost bought this today http://www.summitracing.com/parts/QFT-Q-750/?rtype=10 , but the Summit rep, Brunner x6985 was very helpful and mentioned this http://www.summitracing.com/parts/AED-750HO/ as a cheaper alternative with similar features.
Anybody have any luck with AED? For $125 dollars difference all I see is flash. Is the QF really better?
PRO Systems in Jax, FL is around $640 for a custom built deal.
Today I got a quote from Summit for a Strange S60 at $2100 delivered.
I am also looking very hard at A 9 inch Ford bolt in for the Chevelle in a light configuration for around $1600 or the HD version at around $1950. Either way my brakes will work with the gm ends. I was pleasantly surprised at the price options. I am leaning Ford because of simplicity in gearing options down the road.
QF baseplates have some nice features, like a secondary idle adjustment screw that is accessible from the top, stainless throttle plate, improved throttle shaft seals and the option to put in progressive linkage. Plus that QF model has tunable air bleeds and idle feed restrictors. If the AED has all that then might be a good deal. There are a number of other little things, like huge float level sight windows and the ability to plumb in fuel from either side of the carb.
I will tell you which one looks better.
