Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
e85 carbs
Old Sep 29, 2012 | 11:39 AM
dogsballs's Avatar
Default e85 carbs
I've had great results from e85 in my genIV. So i've got a new drag only project so i'm about to build a nice little 'budget' 346 ls1 combo using stock bottom end (with rod bolts), PRC 227's, tsp ms4 cam, super victor manifold and at this stage thinking quickfuel e85 950 carb. Will try to get as much comp onto it, 12.0:1 will require 56cc chamber and flycuts.
Any feedback is welcome from other e85 carb users.
Old Oct 12, 2012 | 02:55 PM
LT1Altered's Avatar
I bought a Quick Fuel 750 cfm E85 carb for my 11.2:1 compression LT1 with LT4 heads, intake and Hot Cam.
It would completely stall whenever I floored it, even when it was in Park in my driveway.
I tried everything to fix it but eventually send it to Mark Sullens to have it modified.
It works great now and has been very consistent for bracket racing.
I think 750 cfm would be plenty for a 346, even if you're spinning it to 8000 rpm.
I think Mark sells complete carburetors now.
www.marksullense85carburetors.com
Old Oct 13, 2012 | 10:40 AM
dogsballs's Avatar
awesome, thanks for the link. actually gone up to 6.0 litres and L92 rectangular heads.
Old May 22, 2013 | 04:25 AM
linicklo's Avatar
What you end up doing? I'm thinking of making my l92 carb run e85, looking at 12:1 compression ratio
Old May 22, 2013 | 07:02 AM
MikeFSKSpeed's Avatar
I sell a ton of E85 Quickfuels and have had fantastic feedback on them!
Old May 22, 2013 | 09:32 AM
dogsballs's Avatar
just about to get one from eric at horsepower innovations.
Old May 22, 2013 | 01:26 PM
streetknight2's Avatar
Pro systems
Old May 22, 2013 | 03:55 PM
Thunder v2.0's Avatar
I have one from Eric, very quality piece and hes pretty helpful with tuning tips. Out of the box it was really close to spot on, just need to change out low speed bleeds (probably my fault there)
Old May 22, 2013 | 05:08 PM
dogsballs's Avatar
thats what i'm hearing over and over.
even spoken to a guy hear in aus that had issues with pro systems sv1, swapped to horsepower innovations, pb out the box. good mate just got two and he couldn't be happier.
