electric fuel pump question
I'm running a return line because I have a return style regulator, I have had a holley pump and regulator befor and that regulator did not have a return on it so I guess it all depends on what you use. I heard they running a return line helps keep the pump quieter and helps it last longer, also helps prevent against vapor lock
