Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
What will it run?
Old Nov 1, 2012 | 09:02 PM
83_Mustang's Avatar
Default What will it run?
I've got a Mustang that weights around 3100 with driver,good suspension under it,373 gears,400 tubro trans no convertor yet.Thinking about ordering a LSX376 Crate Engine.What do you think it would run in the 1/8th with the right convertor and carb.This car would also be driven on the street.
Old Nov 1, 2012 | 09:32 PM
AINT SKEERED's Avatar
Not sure on that crate engine, is it a stock cam? With that car and even a stock 376 it would go low 11's with a 3500-4000 stall.
Cam it and you will see low 10's
Old Nov 1, 2012 | 11:20 PM
wildcamaro's Avatar
11s no doubt, if lq4 stock motors are doin it you're a guarantee to knock 11s of some type whether it be high mid or low.
Old Nov 2, 2012 | 05:53 AM
ZONES89RS's Avatar
In-Zane Moderator
Low 7s in the 1/8th with no cam. With cam and nasty converter, mid to high 6s.
Old Nov 2, 2012 | 03:53 PM
83_Mustang's Avatar
It has like a 530or 40 hydraulic roller.
Old Nov 2, 2012 | 03:54 PM
83_Mustang's Avatar
Thanks for the replys.
Old Nov 3, 2012 | 02:37 AM
topbrent's Avatar
Are you asking about the aluminum block LS3 based LS376/515 or the iron LSX block LSX 376?
Significantly different engines.
Old Nov 3, 2012 | 10:21 AM
Pop N Wood's Avatar
I was going to say. There are a couple of different versions of that crate motor.
I think summit might list the wrong torque rating for the link above. They are saying 575 ft-lb of torque but other places are saying 470 ft-lbs. The summit price is about a grand more than other sites too.
