Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Popping when accelerating
Old Dec 21, 2012 | 08:17 PM
stevecritt's Avatar
Default Popping when accelerating
Well I took my car around the block for the first time today and when I was accelerating it was popping and running a little rough. thing its the timing?
Old Dec 21, 2012 | 09:15 PM
89gmcs15's Avatar
Check your floats?
Old Dec 21, 2012 | 09:47 PM
willys_truck's Avatar
Make sure the msd box is grounded REAL good.
Old Dec 21, 2012 | 09:54 PM
stevecritt's Avatar
You think I need to raise the floats?
Old Dec 21, 2012 | 10:04 PM
89gmcs15's Avatar
Grounds are touchy and check your float level. If your emptyin the bowls it will pop ( mine was ) it almost seemed like it hit a limiter only sometimes. Turn out my new carb had plastic from the needle and seat packaging stuck around the needle. Don't trust even the best builders I suppose.
Old Dec 21, 2012 | 10:06 PM
pairof69s's Avatar
do most ground the box straight to the battery..?
Old Dec 22, 2012 | 08:31 AM
stevecritt's Avatar
my air fuel is reading below 12 all the way through acceleration. So I would think it's getting slightly too much fuel. I'm going to up the timing a little and see what happens.
Old Dec 22, 2012 | 08:33 AM
stevecritt's Avatar
Mine is grounded to the chassis
Old Dec 22, 2012 | 09:06 AM
toxic99's Avatar
Make sure alt working, if you running off straight battery, then that isnt enough juice for coils.
Old Dec 22, 2012 | 12:34 PM
stevecritt's Avatar
alternator is working, 14v while driving. I found one part of the problem the msd was trying to calculate in the map and advance my timing at idle to 36 deg, so I zeored it, runs a little better. but now i'm getting that rev limiter sputter at wide open throttle. So I'm going to try and raise my floats some and see if that helps.
Old Dec 22, 2012 | 07:27 PM
Ls_Notch's Avatar
Check your plugs to, mine was running like crap and then I swapped plugs and it cleaned everything up.
Old Dec 22, 2012 | 08:22 PM
stevecritt's Avatar
plugs are new. I guess its possible I could have fould them during initial start up and tuning... doubt it though
Old Dec 25, 2012 | 06:48 PM
LS1MCSS's Avatar
Unplug the wires from the MAP and try it.
Old Dec 29, 2012 | 08:08 PM
89gmcs15's Avatar
Any updates on this?
Old Dec 30, 2012 | 10:10 AM
StrokerTA's Avatar
If you are just cruising, driving normal, the floats have nothing to do with it...
Supply the MSD with ground and power DIRECTLY TO THE BATTERY... Then make sure you have adequate ground from battery to frame, engine to frame, etc...
If this is just a street car with a mild cam, it will probably like to have some timing advance in it.. Usually I set my timing curves so it's "all in" by about 2500 RPM..
As for the popping, is it in the mufflers, out the carb, does it vary by RPM?
Old Jan 1, 2013 | 10:36 PM
bcscottdt's Avatar
Mine was doin the same as yours retarded timing fixed problem
