Prepping for first start of carb'd stock LS1 w/ MSD 6010 and Pro-Systems 750 carb
Carb'd LS1 going into a our Panoz roadrace car (build linked in sig). How should I set the carb and MSD box for the first start? I need it to be able to idle and run well enough to break in the motor. My break-in procedure would be as follows:
Specs:
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash3/29591_4626678356205_1295467560_n.jpg)
Thanks,
Brian
PS - I don't have much experience with carbs. I didn't work on the car much when it had the SBFs. I understand the basics and how they work, but not sure how to create a good baseline for starting and running the car.
- Start on 5w30 regular oil
- Let run 10-15 minutes, then change oil/filter using regular 5w30 again
- Run on dyno doing 5-6 75% throttle pulls to 4000-5000 rpms.
- Drive around on dyno for remainder of dyno hour varying gear and rpms.
- Switch to Amsoil 10w40 synthetic (what I run in my Corvette)
- Dynotune car to max 6500 rpms.
- Go beat on it.
Specs:
- 2004 GTO LS1 crate motor (241 heads & stock cam)
- Edelbrock Performer RPM manifold
- Pro-Systems road race carb based on Holley 750 (left over from the 347 SBF taht made around 370 rwhp)
- MSD-6010 ignition controller
Thanks,
Brian
