Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
is this a good cam for mostly stock 5.3
Old 01-15-2013 | 08:44 PM
Blue Knight's Avatar
Default is this a good cam for mostly stock 5.3
Brand:Howards CamsManufacturer's Part Number:190325-12Part Type:CamshaftsProduct Line:Howards Cams Hydraulic Roller CamshaftsSummit Racing Part Number:HRS-190325-12Cam Style:Hydraulic roller tappetBasic Operating RPM Range:2,000-7,200Intake Duration at 050 inch Lift:226Exhaust Duration at 050 inch Lift:232Duration at 050 inch Lift:226 int./232 exh.Advertised Intake Duration:281Advertised Exhaust Duration:284Advertised Duration:281 int./284 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.578 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.587 in.Valve Lift with Factory Rocker Arm Ratio:0.578 int./0.587 exh.Lobe Separation (degrees):112Camshaft Gear Attachment:3-boltComputer-Controlled Compatible:NoValve Springs Required:YesCamshaft Manufacturers Description:Aggressive street/strip, upper torque and horsepower. Needs good heads.Quantity:Sold individually.Notes:Requires custom programmer/tuning.
I will have a victor jr and probally a 650 carb spraying a 200 shot
Thanks
Old 01-15-2013 | 10:10 PM
orange88ls1s-dime's Avatar
Should work but see if they can grind it with 108-110 degrees of overlap
Old 01-17-2013 | 11:13 PM
5.3dime's Avatar
My cam is similar to yours, all stock 5.3 victor jr 650 dp made 338hp to the wheels. That was turning a th400.
Quick Reply: is this a good cam for mostly stock 5.3
