Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Fox body LS, ZONES style
Old 05-25-2013, 12:59 PM
  #181
jgillen91's Avatar
Originally Posted by ZONES89RS
Oh yea, plenty. I really want to go to a 4.11 gear too but I want to drive it on the street too much.
I wouldn't change the gears till you get her all sorted out. Put a set of 275/60/15 radials on it. Should go 1.5x 60' 6.9xx -6.8xx
Old 05-25-2013, 02:06 PM
  #182
In-Zane Moderator
ZONES89RS's Avatar
Has 26x11.5x17s on it now. I know a drag pack would help though with some light 15s.
Old 05-27-2013, 04:57 PM
  #183
05 GSXR 1XXX's Avatar
Very nice sir! Last fox I had was rough and restored but sold before I could make any real power.. Very cool to see a Ls fox!
Keep up the good work and keep the updates coming!
Old 05-27-2013, 05:11 PM
  #184
In-Zane Moderator
ZONES89RS's Avatar
For sure!
Just took it for a test drive and ran it to operating temps. Then ran it through 1st and second 5 times. Oil pressure went from 36 at operating to 28. So its better than last Friday. Hot lapping had it just above 20. So some thicker oil will do.
Checked the plugs, they are lean. Funny since the car was running 11.5:1 when it was in the camaro with the same carb. But, between having a 5/16 return and now it has 3/8 feed and return, also from the regulator sitting, fuel pressure was 4 PSI. Im sure there is some MPH and ET missing from that alone. We will see next Sunday if weather is good. Unfortunately i will be cutting weight, adding the carb spacer and hopefully getting the jetting dialed in, so i will not have a back to back comparison on the running lean.
But, good news to know it was lean. Bumped it to 7 PSI already. That means power on the table.
Old 05-27-2013, 09:15 PM
  #185
jaywill's Avatar
Thats goid to hear..r u thru running the firebird
Old 05-28-2013, 06:33 AM
  #186
In-Zane Moderator
ZONES89RS's Avatar
Just dying to know how much power I was holding back.
Trans am is done. Will dial in the carb, but she should be done with track time. It's a fun car for a girls ride though. I know there are plenty wanting me to push it further.
Old 05-28-2013, 09:53 AM
  #187
Z284thgen's Avatar
there is aprox 175lbs of weight to be pulled from behind bumper covers front and rear pull inner fender liners heres crap behind them and then all the sound deadner stuff inside the car behind all the interior trim
I just did this to mine over last couple weeks but haven't ran it since
Old 05-28-2013, 10:33 AM
  #188
jaywill's Avatar
if mine runs that good i'll be ok...
Old 05-28-2013, 02:19 PM
  #189
In-Zane Moderator
ZONES89RS's Avatar
Front impact bar is already gone. Still can remove the rear and door bars, ect. Want to weigh the car today, but I don't think I'll have time.
Old 05-28-2013, 02:33 PM
  #190
TxFireman1972's Avatar
I did did a tubular front and tubular radiator support when I had the front end replaced. Going to order a rear tubular rear bumper from these guys:
http://www.donathenracing.com/Products.html
Old 05-28-2013, 02:38 PM
  #191
Here is the front
Old 05-28-2013, 02:49 PM
  #192
In-Zane Moderator
ZONES89RS's Avatar
Thats some race car stuff right there. I dont have money for that. I will make a support for the rear, but the front is fine.
Old 05-28-2013, 03:34 PM
  #193
Lol, actually the front one was on the new front clip I bought. The lower radiator support I went ahead and did because the old one was just a piece of angle iron. Honestly , any of them could be easily made. I just don't have a tubing bender.
Old 05-28-2013, 04:23 PM
  #194
In-Zane Moderator
ZONES89RS's Avatar
That is something i would like to have. As much as i fabricate stuff, it would be a big help....
Old 05-30-2013, 02:00 PM
  #195
jmac636's Avatar
Damn your **** rolls out! Wish my 5.3 ran half that good.
Old 05-30-2013, 03:05 PM
  #196
In-Zane Moderator
ZONES89RS's Avatar
That's allot to ask from a 5.3 liter, in a gutted mustang it's not, but anything heavy.
Old 05-30-2013, 07:02 PM
  #197
Lawhead's Avatar
My bad man been so busy selling this damn Firebird and I'll be on vacation next week so if you want them lights I'll probably give them away for 20 bucks plus whatever it cost to ship them think I'ma go to a U-Pull it and hopefully find all the other **** I need then I can get this thing breathing fire!!
Old 05-30-2013, 08:20 PM
  #198
In-Zane Moderator
ZONES89RS's Avatar
Sounds good to me man! I'm good with that! Hope you can finish up. I have a rear sway bar to pick up from a friend, a wiper cowl as well. Then I need to remove some weight and get to the track. The wide band cable that the dog ate has been replaced as of today as well. Going to install my 2 inch spacer and chop up my hood so it will have a scoop made from a spare hood.
Old 05-31-2013, 04:50 PM
  #199
In-Zane Moderator
ZONES89RS's Avatar
Took her to the scales and she is roughly 400 pounds lighter than the 89 RS was. This is with me in the driver seat, i am 320 pounds. This is with the 10 gallon cell full as well.
The RS was 3450 with me in the seat.
Makes me know there is a ton left with the fuel at 4 PSI. Hard to believe i only trap 1 MPH better than my 89 did with 400 less pounds.
Old 06-01-2013, 01:50 AM
  #200
In-Zane Moderator
ZONES89RS's Avatar
One of the videos my wife made. The other has not uploaded for some reason...
Quick Reply: Fox body LS, ZONES style
