Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Add tail pipes, added 4 mph
Old Mar 23, 2013 | 10:01 PM
ridnhood's Avatar
Default Add tail pipes, added 4 mph
Went to Mir today, ran my junkyard 6.0 in that ran a best last year of 10.31@ 129 on slicks, put on nitto 555r radials today added stock lx/gt tail pipes. 1st pass 1.92 60 ft. 7.17 8th @104 and 10.89@ 133!! Blew the tires and let out cleanly. 2nd pass 1.75 60 ft 6.89 8th @ 105 and 10.60 @133.3. Never pulled like this till I put on the tails. Has anyone else on here tried tailpipes?
Old Mar 24, 2013 | 06:30 AM
ZONES89RS's Avatar
In-Zane Moderator
Have heard many mph higher spinning. Get it to stick and ET for good data.
Old Mar 24, 2013 | 02:14 PM
ridnhood's Avatar
True, but it has never pulled like that before...
Old Mar 24, 2013 | 02:15 PM
lemons12's Avatar
What was the DA difference?
Old Mar 24, 2013 | 04:23 PM
ridnhood's Avatar
Don't know for sure, that was last oct. Also I never spun on second pass, kind of slowly mashed it out the hole.
Old Mar 24, 2013 | 07:24 PM
Lawhead's Avatar
Kind of broad comparison lol
Spinning usually results in better MPH and I'm sure on a radial you will tend to go faster as well and weather and D/A and that also plays into it
Old Mar 24, 2013 | 09:11 PM
GC99TA's Avatar
I'm gonna guess your MPH gain was from the DA and not the tail pipes. I was at MIR Saturday with my car as well and the DA was KILLER! It was negative all day long. It was nearly -1000ft on my first pass. The car ran it's best ever on motor.
Old Mar 24, 2013 | 10:51 PM
toxic99's Avatar
Id say it was more the drag radials then anything. That and DA.
Old Mar 25, 2013 | 06:35 AM
jleews6's Avatar
What tire was on it before? A radial will (most times) show more MPH.
Old Mar 25, 2013 | 06:56 AM
Tweek's Avatar
Was def a result of the tires. I have a h/c 6.0 fox body, about a month ago went to the track on 295/55 drag radials and trapped 132. Went back 2 weeks after and the only change was to 28/11.5 et street bias plies. Car dropped down to 129 and the da on both days was around +200 feet
Old Mar 25, 2013 | 10:31 AM
ridnhood's Avatar
Yeah, it had mt slicks in oct. it's probably a combo of all factors, may try this weekend w no tails, air may not be the same though. May give her a 150 shot of different air in high gear if those nittos will hold.
Old Mar 25, 2013 | 11:13 AM
menchaca's Avatar
It is the tires. Spinning results in slower 60' which gives your car more time to pick up mph.
Old Mar 25, 2013 | 06:57 PM
Tweek's Avatar
Good luck on your trip back. You running an auto? Can I get some details on the motor setup?
Old Mar 25, 2013 | 08:01 PM
89gmcs15's Avatar
Set the exhaust to how it was last year and see f the mph drops?
