MSD 6010 timing with Carb'd LQ4
Hi,
I'm not on the site much, but I've looked pretty extensively for solutions my problem but haven't found exactly what I needed. With that being said, If there is another thread with this topic I apologize; please redirect me to that tread instead.
Anyways, I have a '67 Bird with a LQ4 from an 05 Chevy 2500. Under the intake the motor is all stock. I currently have an Edelbrock Victor Jr. Intake with a Holley 750CFM Vac. secondary carb installed on it now. I have tuned the carburetor based on vacuum, with the help of an archaic narrow band AFR gauge, so I don't think this setup is related to my problem.
I'm working with the timing for a while now, and while it seems like I've got it mostly dialed in, I am simply wondering what others are running timing wise with this MSD box on a lower compression 6.0L. When I really step on it, it seems as though I either have a problem with detonation or the motor bogs longer than it should. 87 or 91 octane doesn't make a difference.
Thanks in advance for any insight!
I think you could add 2* of timing everywhere, and you could bring it in sooner too. also your map could carry aadded advance further- out to 7-8psia, or there abouts.
That said, have you messed with the accelerator pumps on your carb?, that is usually the first place to look when you have a bog upon hitting the throttle. my 6.0 when stock wanted 35 shooters, and an aggressive pump cam setting
As for the accelerator pump, I've tried different cams, but haven't messed with the squirters. If the timing doesn't change any thing, I'll keep on working with the carb.
