Left bank going lean with Edelbrock Performer RPM LS1 manifold?
Update - Dyno'd again today. The plenum milling fixed the air/fuel imbalance. Car was only 0.3 air/fuel different bank to bank.
Car made 323/351 hp/tq with 13:0 AFR and only 22 degrees timing. Couldn't get the car to fatten up any. Upped the jets in the secondaries from 79 to 82 to 86 and air fuel only fattened up to 13 which is way less that it should have. Turns out the air bleeds had all been drilled out haphazardly and we only had four blanks. Going to have Pro-systems send a fresh set and try yet again. Trying to get air/fuel in the mid 12s before advancing timing. Car has a good bit more power/torque left in this stock LS1.
6K pull, 22 degrees timing, 309 rwhp, 357 rwtq (stock 2004 GTO LS1 crate engine). Left bank going lean in mid-14s per tailpipe wideband vs. mid-12s on right bank verified by onboard wideband and tailpipe sniffer.
A fellow LS1 swapped Panoz owner told me he had the same issue and had to cut the center divider out of the manifold.
Has anyone else had this issue? Most cars have an H-pipe or X-pipe blending the exhaust which would potentially mask this. I'm going to weld a bung in the driver's side pipe to verify the lean reading seen on the sniffer.
It's a dual plane manifold, each side of the carb feeds two cylinders on each bank. Something about the design seems to be leaning out the left cylinders. Trying to see if anyone else has had issue with this manifold.
Edelbrock's tech said:
1. They didn't see anything like this in testing. 1/2 point AFR variation bank-to-bank max.
2. Some of the Performer RPM manifolds come with the center "wall" cut down already. Suggested doing it, but not more than 1/2". Said it'd lose some low end torque, but not material for my application in a 2500 lb car.
Here's the Performer RPM off the 347 SBF we had in the car before.
![](http://i39.photobucket.com/albums/e158/cvbowers/Auto%20Parts/DSC_0031_zps7e31aa37.jpg)
Generic picture of a SBC manifold w/ the same "cutout"
![](http://www.reidsrodparts.com/images/engine/edl-7501.jpg)
3. Said they never trust tailpipe sniffers.
Just throwing this out there but couldn't you jet your one side alittle fatter than the other? I'm only suggesting this if your plugs egt's and widebands are all showing a lean mixture across all holes on one bank vs the other. Call me stupid but it seems as if you should set the engine to work how it wants to, not make te engine work how you want it to. Like tuning a itb or multi carb (ie. 8 singles) vs one "main" setting across the board?
How's that going to work when the left side feeds two cylinders on the left bank and two on the right bank? Jetting up the left side of the carb will add fuel to two cylinders on each bank. Might get the lift side reading in the correct range while making the right bank run rich.
none of the holes for mounting the ignition box are all the way through are they? I think I saw one somewhere that the hole was open to the intake and cause some problems.
One of them is, but I put a bolt in there with thread sealant per the instructions. We tested for air leaks with brake cleaner on the dyno and found none. Going to put the bung in the driver's side bank and mill the center divider. The folks at Pro-Systems said they've had similar issues using the dual planes and do the same thing. They prefer the dual planes for road racing vs. the single plane.
Noted. However, the exhaust is all new (I built it) and fully tig welded. I'm going to put a bung in the driver's side to verify the lean condition just aft of the manifold.
I can't swap it to the left until I weld in a bung. I didn't bother putting a bung in the driver's side when I built the exhaust. The onboard wideband is an AEM UEGO which is the one I have in my Z06 as well. I have no idea which brand sniffer the shop was using.
![](http://www.aemelectronics.com/images/digital-wideband_cat.jpg)
EDIT - If you meant the sniffer, then yes. Putting the sniffer in the passenger side where my onboard wideband is resulted in them both reading mid-12s. Sniffer in the driver side pipe resulted in mid 14s. I'm going to put a bung in the driver side pipe and mill the plenum divider some.
