Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Throttle cable
Old Jun 15, 2013 | 05:37 PM
LQ4BU's Avatar
Default Throttle cable
Hey guys,
I have a small issue with my set up. I have a 750 Demon carb on a LQ4, which is in my 79 Malibu. If I set my throttle cable to give me full throttle, then it doesnt close enough, causing the engine to idle about 1100-1200rpm. If I adjust the cable to give me a lower idle, then I'm not getting full throttle.
Do I need a longer cable....or do I need more travel in my pedal? The longer cable would just make the problem worse wouldnt it?
An aftermarket cable wouldnt solve anything would it? To me it seems I need more travel one way or the other in my gas pedal??
And another question....what do you guys recommend to be "full throttle" on your carb?? Do you think it needs to be open until the blades are perfectly straight up and down....or a slight pitch towards the front of the carb??
Old Jun 15, 2013 | 07:48 PM
snook's Avatar
I had to cut off some of the little plastic piece off of mine, same problem, it was bottoming out before I could get wot. The round tube ay the end of it
Old Jun 15, 2013 | 10:24 PM
LQ4BU's Avatar
Yea, I did the same thing...the round tube that covers the cable?
I think my problem may be I had the cable adjusted to much towards wide open throttle. I talked to some local guys and they also said that you dont want the throttle plates perfectly straight up and down, I guess they are supposed to lean just a tad towards the front of the carb as I thought.
Readjusting it that way should give me just that little bit, allowing the idle to drop around 800-900.
Old Jun 16, 2013 | 06:11 AM
Doug G's Avatar
Yes, you don't want to open until it hits the stop...you'll end up bending/twisting a shaft and/or wear out the bushings faster.
Old Jun 16, 2013 | 06:52 AM
ZONES89RS's Avatar
In-Zane Moderator
I have had it close like that. A stiffer throttle spring pulled it all the way closed.
