Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Need some input on build
Old Jun 29, 2013 | 02:57 PM
superfly85's Avatar
Default Need some input on build
I have 46 Chevy rat rod should weigh 2000-2500 lbs.
4.10 gears, either th350 or 700r4.
Its getting a carbed 5.3 stock except for open headers.
I need some suggestions on cam and convertor.
It will spend 90% of its time street driving however I want it to sound nasty and perform as best as possible while being streetable. I was looking at cams like the asa and edelbrock 2215 and 2216 because I can use cheap springs and possibly find used cam.
Old Jun 29, 2013 | 11:57 PM
ZONES89RS's Avatar
In-Zane Moderator
The 2216 sounds great and runs good in my TA. You could use LS6 springs and stock pushrods.
Old Jun 30, 2013 | 12:45 AM
superfly85's Avatar
Ive seen vids of your car it runs really good. What kind of stall would I need to run? Also a member offered me a custom ground 230/230 612/591 111+2cam with springs. Better or worse than a 2216? Too much for a 5.3.
Old Jun 30, 2013 | 05:28 AM
ZONES89RS's Avatar
In-Zane Moderator
That would work well for a budget. The higher lift would be good. The 2216 is only .540. Would work great either way with a 3200 converter.
