Carb + stock ECM?
I know some here are using their ECM just for ignition. What all are you doing as far as the tune to keep the ECM from going crazy? Just disabling the codes? I'm using HPTuners ...
Because I have the ECM in place, wired, and running already and its perfectly capable of controlling the ignition. I know people have done it on this forum in the past ...
I have HP Tuners and have looked into it. I'm no pro tuner yet but I know my way around it a little. It seems easier than it should be, hence my reason for asking. You must be a tuner since it is so obvious to you that I am not and you are so certain that it is not worth the headache. Can you explain it to me?
For instance, what does the computer do when it tries to adjust fuel trims and nothing happens? It throws a code. So is disabling that code all that is necessary or do I zero out the fuel tables somehow?
Either way I would be doing my own timing tables. So Why waste the money and time installing the MSD, learning their software, and replacing my ECM when my ECM is perfectly capable of doing what I need, I already know the software, and its in place?
You might not be getting much help because I honestly don't know of anyone on here who has done what you are asking. Seems like a good idea given the situation you are in. I agree it should be doable, but like said above, when they work the MSD boxes are pretty ****.
SOMEONE here has done it:
https://ls1tech.com/forums/pcm-diagn...g-control.html
That thread seems to be inactive at this point though, hence starting a new one.
"More?" Qualify that statement please. Having seen inside the GM programming I can't imagine what else such a small company could offer? I have no clue what they do offer though. Just know that MSD is pennies on the dollar in terms of R&D put in as compared to GM.
And those MSD boxes are not known for reliability. The few people I know that use them carry a spare, which doubles the cost.
I PM'ed 10sec_rx7, this is what he had to say:
Originally Posted by 10sec_rx7
piece of **** mate,
just have to put a VE table that would roughly represent your motor as the timing map is a calculation off the ve table, once that is done turn off the injector codes and away you go,
it just works and works really well
I would thing you would go SD to ditch the MAF, and do as Originally Posted by 10sec_rx7
Just have to put a VE table that would roughly represent your motor as the timing map is a calculation off the ve table, once that is done turn off the injector codes and away you go.
(Link to MSD 6010 instructions.)
In-Zane Moderator
It has the ability to use a MAP sensor. Besides timing control, you also get a 2 step built in rev limiter, timing retard for nitrous, there is a idle control feature for efi, it. An be used for boost as well.
As for reliability, I have done at least 10 carbed LS swaps off the top of my head and the one I have seen failure was not done by me. He had poor grounds that burnt the box up.
I never doubted someone had done it. Just trying to be helpful and say no one was answering because is a very uncommon swap. No one I know on here has done it. I now know of 1 and possibly 2 members who have.
Post results when you get it running.
BTW, I've never had an issue with the MSD box. They are sort of like Volkswagens, you either get a good one out of the box or you don't.
Now pretend the race track is 20 miles from the closest town with a parts store ... and you're working on your race car in the dirt ... and its raining, hot, and humid ... and your tooling is limited since all your best tools are at home ... and you have lots of experience with a a different fuel system that doesn't use injectors or fuel pumps at all.
This is where I am at now ...
