custom timing curve
Wanting to put a custom timing curve in my car its drag race only so trying to get the most out of it. looking for any suggestions
engine spec.
iron block 5.7 (5.3 punched out)
232/238 .620/.612 112+3
ported 853 heads with 54cc combustion chambers
holley 780 carb
best guess on compression is 12.5-13.0
engine spec.
holley 780 carb
This is just a guess, so your is probably as good as mine. With your compression, I wouldn't think you would require a ton of lead and with a 5.7 running a cam that size, I would suspect peak torque would be in the 5000-5200 rpm range. As a starting point ,I would do 30* by 1200 rpms and carry that to around 4900, then taper down to 27* by 5000. Carry 27* to 5300, then taper back up to 30* by 5400 and carry 30* to the red line.
I think that curve is pretty close to where you need to be. Try that and add 2* with the same curve dip and see if you gain or loose. Experiment from there to find best MPH. good luck!
