msd 6010 box problems
Did you do anything to the harness, like swap out cam sensor plugs? The cam sensors for the 24 and 58 tooth reluctors are wired differently. The output posts are labeled A-B & C and each map to a different color wire. Check a wiring diagram.
MSD actually has respectable customer service. If it is wired right give them a a call.
Another guy told me of same symptoms with loose cam bolts.
