Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
A/F help for n/a,and for bottle..lq4 fox
Old 10-07-2013 | 10:12 PM
Builtz71's Avatar
Default A/F help for n/a,and for bottle..lq4 fox
Long story short:
Went 11.00@123 on motor with a/f at 10.2:1 or so...real fat..prob 6-7 months ago..
Been tinkering with jets lately,got the all motor a/f to 13.2:1 car feels real strong..
Well got a good deal on a used NOS cheater kit set at 125 shot..
My question is what would be a decent a/f on bottle?,and about how much timing should I pull for the shot?..on 110/91 octane mix,with a br7 plug
Plan on going to the track this Friday..hoping for high 10's on motor now,and possible low 10's on bottle..you guys have always been a big help when I'm reading the threads..thanks for any help
Old 10-07-2013 | 10:26 PM
74u's Avatar
74u
What't your combo? Motor, stall, gear, tire, weight...sounds like a strong car.
I think the consensus is 12.0 - 12.5:1 afr on spray. BR7 plugs and pull 2 degrees per 50hp of nitrous. More than safe starting point considering you are adding race fuel.
Old 10-07-2013 | 11:04 PM
Builtz71's Avatar
Lq4 .30 prc heads cr is around 10:8.1 with heads..comp 235/243@112 cam..qft ss750 carb,,,th400 trans,circle d 4000 stall,4200 on t-brake..3.73 gear..275/60/15 e/t street..2950lb without me..
Right now I have the br7's gapped at .30..30* timing pulling 6* for bottle
Old 10-08-2013 | 07:19 AM
ZONES89RS's Avatar
In-Zane Moderator
74u is spot on.
Old 10-08-2013 | 08:58 AM
Builtz71's Avatar
thanks guys..ill let you know how it goes
Old 10-08-2013 | 09:03 PM
streetknight2's Avatar
My car runs best at 13.1-13.2 AFR on motor.
Each motor is different. I'm on a 100 shot and using 93 octane I have to pull 8 degrees from motor tune with br7's gapped .030"
Quick Reply: A/F help for n/a,and for bottle..lq4 fox
