Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Stall
Old Oct 17, 2013 | 03:33 PM
Jesus Martinez's Avatar
Default Stall
Is a 3500-3800 stall too much for my 5.3 cammed th400?
Old Oct 17, 2013 | 04:39 PM
ZONES89RS's Avatar
In-Zane Moderator
What weight, gear, cam specs?
Old Oct 17, 2013 | 04:43 PM
Car is my notchback weighs about 2800 and cam is under 580 112 lsa for now and gears are 3.55
Old Oct 17, 2013 | 11:32 PM
ZONES89RS's Avatar
In-Zane Moderator
It will work. May be perfect for you, but you won't know till you try it.
Old Oct 18, 2013 | 12:22 AM
bears416's Avatar
They say as a rule of thub a stall 500rpm under where you make max torque is good, but theres exemptions
Old Oct 18, 2013 | 07:20 AM
newschool72's Avatar
If you have the stall in hand , I say go for it. Your duration #s would help figure out whether the stall is close. With a 5.3, I think the stock torque peak is around 3800rpms , so even on a stock cam 5.3, that's not too much converter. The big thing about stall speed on a converteris , the stall speed is relative to the engine its tested with at the manufacturer and the engine the end user has. In a BBC ,that stall will be much looser than in your 5.3. The higher the torque, the higher the stall.
Old Oct 19, 2013 | 10:57 PM
What about the bell housing to the motor will it just bolt on??
Old Oct 20, 2013 | 07:49 AM
speedtigger's Avatar
Old School Heavy
Most guys on LS1Tech say that even the stock motor needs a 4000 stall.
