Which LS based engine..
I was wanting to build a n/a 370 out of a 6.0 iron block. But I have heard to convert to a LS intake you have to change the accessories.
So basically should I spend the extra money on a LS1 from summit or go to my local junk yard and buy a 5.3 or 6.0?
When I rebuild ill be changing my setup from strip only to street and strip and would love to have it where on a programmer I can go from a easy riding car to full blown beast.
A junkyard engine is a fan favorite and my 6.0 in my camaro went 7.1s and in my lighter mustang runs 6.9s all motor in the 1/8th. Which is much slower than many of the other guys that have better heads, converter and gears.
So it depends on how hard you want to run. My 86 TA with a salvage 5.3 runs 7.7 all motor in the 1/8th. Didn't even really tune it.
Accessories? I run the truck pieces.
Well is a 370 a good platform or should I just save the money get a low mileage 6.0 and leave it stock short block and throw cam and heads in it.
btw when running carb on a ls based engine how exactly does the coil packs work?
Flex Fuel 5.3L LC9
LS1 08 Silverado Engine 55K miles. (Craigslist) ($950)
MSD Ignition 6012 - MSD Ignition Controller for GM EFI/Carbureted LS Engines: (Jegs) $349.99 http://www.jegs.com/i/MSD+Ignition/121/6012/10002/-1
Edelbrock 71187 - Edelbrock Performer RPM Manifolds & Kits for Chevrolet: (Jegs) $265.99
http://www.jegs.com/i/Edelbrock/350/71187/10002/-1
Flex Fuel 5.3L LC9
We ran a msd ignition for a while but when we would shift there was a horrible pop to it so we just yanked it and rebuilt the stock distributor.
I was actually just looking on Chevrolet performance, and in order to keep my car still reasonably priced I will probably go with a 6.0 from the work truck models (if I can find one) and put a hefty cam and have the heads worked.
Also I read that the MSD has a 2step launch, Ive seen them in action but never got a chance to ask about them, could anyone enlighten me?
-Kyle
-Kyle
There are many knowledgeable people hanging out on this site. You have a lot to learn about the LS platform. Hang on and enjoy the ride !! Its a lot of fun.
