Pump Shot Help
I have been chasing a lean condition at tip in forever. Worse at take off, but occurs at cruise as well. Carb has a 50cc nozzle, 50cc pump kit, and yellow cam installed in no 1 position. With this setup, the condition is at its "best" but its still lean. Confirmed with wideband and physically feeling the stumble. With that said, I think the size of the shot is right since the engine recovers quickly, but I need it to hit sooner.
Any suggestions besides changing carbs would be greatly appreciated.
Stock 65 power valve
Will have to confirm idle vac. It was around 15" last time I looked
Screw are 1.125 turns out
LSA is 113
Second make sure the butterflies are set so that 20 thousands of the transfer slot is visible on both the primary and secondary. If you need to tweak the idle speed make sure you adjust the primary and secondaries equally. If this causes less than 20 thou of the transfer slot to be exposed, then back off on the idle timing by lowering the 500 RPM setting. Only tweaking the 500 RPM setting lets you come right back into more timing when you get off idle.
If you do those two things you will most likely be able to switch back to the 30 cc pump. I had a 50 cc pump for a good long time cause that is what everyone on here said needed to be done. All the larger pump did was mask the mistuned transition circuits.
One last thing, make certain the accel pump arms are adjusted so even a slight throttle movement causes a good strong squirt down the throat. There should be no slack in the linkage so that you are quick on the trigger.
By the way, if the IFR and air bleeds aren't adjustable on your carb, then drill them out and replace them with set screws you drill yourself. I had to do that on the double pumper. Scary to think about but really quite easy to do.
In their eyes, my truck is heavy and needs Vac secondaries.
I'm hoping to find someone local that has a 650 or 750 DP that I can throw on and test drive to see if its worth buying another carb.
If you want to buy a bolt and go carb, Holley Ultras are reported to work better on LS motors out of the box than the old school carbs.
But any carb you buy may need to be tuned.
