Need Carb Help
Ask anyone who's done a s10 v8 swap or owned a 4.0 powered jeep xj and they'll tell you the same thing. Airflow AFTER the radiator matters and you have very little of it.
Still had the issue of running hotter than I would like and once it was warm, diesel on shutdown. Ended up installing a solenoid on the throttle so the blades would close completely at shutdown.
The truck still runs warmer than I think it should , but it has zero driveability issues. I have too many other projects right now to care that its not 100% perfect.
I can't get my idle down without closing the throttle blades completely, which causes a horrible part throttle drive.
I have lowered the timing to almost 0 which causes engine to heat up at idle, I have also switched from the orifice type pcv to the standard type, I have even blocked off the vacuum line completely, and disconnected all vacuum accessories, and checked for vacuum leaks, all to no avail.
I am running a iron block ls1, 5.3 bored to 3.89, stock 2000 ls1 cam 735 quick fuel carb, vacuum secondaries.
Would a single plane intake make a difference?
What about an open spacer? If the engine was pulling in air and fuel from all 4 barrels would that reduce some velocity? And or vacuum? Currently about 20 inches of vacuum.
What is the current power valve size?
Carb is brand new quick fuel 735 cfm
I had a used 650 road demon on it first, and I just knew that it was causing all my problems, $535.00 later, still the same!
Maybe a cam change? I don't know I am not giving up yet, engine runs great, just idles like crap.
I ended up using professional assistance to get mine sorted. It was cheap and quick! If you are near Houston, let me know and I will point you towards the man.
I am in Atlanta area, to be more specific, I am 5 miles from summit racing in McDonough GA.
